show identity-management
Description
Displays the identity management feature configuration.
Syntax Description
Default
N/A.
Usage Guidelines
None.
The following command displays the identity management feature configuration:
# show identity-management
Identity Management                   : Enabled
Stale entry age out (effective)       : 180 Seconds (180 Seconds)
Max memory size                       : 512 Kbytes
Enabled ports                         : 1-26
FDB Detection Disabled ports          : None
IPARP Detection Disabled ports        : None
IPSecurity Detection Disabled ports   : None
Kerberos Detection Disabled ports     : None
LLDP Detection Disabled ports         : None
Netlogin Detection Disabled ports     : None
SNMP trap notification                : Enabled
Match Criteria Inheritance            : On
Access list source address type       : MAC
Kerberos aging time (DD:HH:MM)        : None
Kerberos force aging time (DD:HH:MM)  : None
Valid Kerberos servers                : none configured(all valid)
This command was first available in ExtremeXOS 12.4.
Kerberos Force Aging Time information was added in ExtremeXOS 12.6.
Platform Availability
